Mechanical changes: '73-'74
MaineShark
Rockingham County, NH
1979 L82, 1987 Buick Grand National
I've seen several mentions of mechanical upgrades being made to the '74 model year vs. the '73 (other than the obvious exterior differences). I was wondering if anyone knew what got changed?
Joe
New in 74;
one piece seatbelt
different fan clutch
fan shroud, seal & mounting
two horns and relay moved to interior
alarm horn switch moved to front fender
evaporative emission canister connected differently
carb jets/metering rods different - smaller opening
heads & intake manifold different
wiper motor
master cylinder &booster
AIR not on cars with THM400
FE7 suspension offered
that is all I can think of now. Get the NCRS judging Guide it will lists alot of info.
Roger
RMS73 said:
New in 74;
roger,
The A.I.R. system was not used on the L48 with Federal Emissions and the automatic. Calif, high altitude, and 4-speed L48s had the A.I.R. along with all L82's and LS4's.
tom...
74 improvements over 73
Here are some more improvments of the '74 over the '73:
Improved TH400
Magnets in PS system
Larger inside rear view mirror
Muffler resonators
Improved Astro ventilation
Improved radiator
Fully Electric Oil Pressure gauge--no worries about oil leak into passenger compartment
