vetteKID
To begin, my car just came out of winter storage, I took it to the mechanic to tune the new Edelbrock 600 carb, and replace the two front brakes. And I was quite happy when I got it back, ran well but still not as strong as it was when I bought it, and I did get on it a little bit. So I park it for the night, next day go to take the girlfriend for a ride and it runs like crap. Sputters, pops, will hardly hold an idle and back fires when you drive it. I knew the car had some valve tap, and it actually did go away the day I got it back. So I make it back to the mechanic and he spent a day trying the timing, carb, ignition, firing order. He pulled the valve covers and said that valves were bad. I came over and looked at them. The valve springs were off center by an 1/16 to 1/8 of an inch on the 3rd 4th and 8th cylinders (I don’t know whether it was exh or int). He said that I need to rebuild the heads, Could this be true? if so, new heads? upgrade the compression and new cam? Any ideas?
