yellow_2002_germany
Recently on my car I saw "Charge System Fault" in the DIC. When I looked up the DTC only B2605H was listed. According to the service manual all electric seat problems are set as H codes even if current. Looking on OBDII.com the specific problem is "Seat Front Vertical Position Sensor Failure/Aft Position Out of Range" I cleared the DTC and am waiting to see if it returns. Both seats appear to work correctly and travel through the full range of motion, forward/aft, up/down.
However, does anyone have an idea what may have caused the "Charge System Fault" to come on? I monitored the voltage on the DIC on my way home and it was in range of what I usually see 13.7-14.1 volts and the battery was at 12.2 after I got home and shut the engine down. It went down to 11.7 as I put the windows up but went right back to 12.2 after they were up and no load was on the battery.
