Tubs and frame rails
Hello
I first would like to thank 67 heaven for posting the pics for me, I had forgotten to mention that in my previous reply
I sent 67 a couple of more pics which are a little more clear of the tubs and rear frame
The rear tires for this car are 19.5 X 33 in Mickey Thompsons and I have a narrowed Dana
I made molds of steel wheel tubs and added a radius to the mold to give a more of a factory look. You can also see the frame and shape of it, and I also made molds of the rear frame rails and glued them into the rear of the car when the frame was in place. I taped 3/8 inch wood to the frame and then pushed the fiberglass pieces close to them so it has a nice close fit (3 /8 in) between the rail and floor
I kept the Corvette center floor section and cut it at certain points, then reglued it back into the car to fit the new frame design. I was told by some chassis shops that I would have to get rid of the storage compartment.
I thought it would be a nice touch to keep it, so I narrowed it 20 inches and raise it about four inches. I am able to clear all of the drag related rear suspension components with it, four link, coil overs, wishbone track locater and the anti roll device. It is not too big, but is good enough for a his/hers sub and a pop.
When I had the body still in the octo-jig, I rolled it upside down and then smoothd out the glass tubs and frame sections. I then put down another two layers of cloth in full sections with a cloth from a pattern maker, I had obtained. This makes for a very smooth look underneath but in a fiberglass mat finish. I will be undercoating the tubs area for sound and stone chips
The inside of the tubs will be finished , but I not sure exactly how yet. I had thought of obtaining paint from a marine supply depot which is used as a deck paint. It has a sandy texture to it, but I am open to ideas on this one.
I fear that it would not last too long to stone chips if painted nicely and I don't want to cover them up with fabric...so I dunno!
The car is quite strong now in the back area and is not much heavier than the aluminum would of been. It was quite a bit more work doing it this way, but as you may of figured out already, I wanted something a little different
take care
Tom
