TWINRAY
- Joined
- Jul 24, 2003
- Messages
- 451
- Location
- Long Island, NY
- Corvette
- '67 Goodwood Green Coupe, '69 Lemans Blue Roadster
All worked well the first time I used it on my '67 but on Saturday I had to bleed the brakes on the '69 after a 4 caliper seal rebuild. For some quirky reason, I didn't have a good seal on the unit and a quart of silicone brake fluid ended up on my garage floor. And it happened quick. I saw it leaking from the rear side of the master and before I knew it, I looked on the floor and ****. Now I did use a C-clamp with a block of wood on top of the adapter so I don't know WTF happened but I wasn't a happy camper. After reshuffling the adapter and tightened the C-clamp, the second attempt was a success. Just make sure it doesn't leak because with the pressure, it does not take long before it's so long $20.
