ECM progress - replaced ECM # 3 it works but --
Cold start problem - engine starts -choke set - fast idle then it stalls - like a lean condition.unplug distributor ecm harness or coolant sensor and it runs in open loop without the engine stalling.When engine is warm and ecm goes to closed loop it runs great.Problem exists when engine is cold - open loop.
Parts replaced
oxygen sensor,coolant sensor,dist.module,ecm,egr and pvc valve ,new carb.
Any suggestions;help
Parts replaced
