norvalwilhelm
I did not have a parking brake for years. The old mechanical one was too much trouble so I ditched it and decided to build a hydraulic one.
I raided my sons supply of various brake parts and came up with calipers with 2 live pistons that would fit my 12 inch rear rotor, a master cylinder that was very light, matches the calipers and easy to mount. I also used my old parking brake handle and a 3 inch piece of 2 ½ inch aluminum angle and a 2 ½ inch x 9 ½ inch by 3/16th piece of aluminum to mount the whole thing on.
I took the stock parking brake handle and added a spur on the back. I bent a piece of 3/16th by 1 inch hot rolled around a ¾ inch pin, machined a little spur from ½ inch material and silver brazed it on the back. I then drove the stock 3/8th spring pin out of the assembly and installed a longer one including mounting my spur at the same time.
Another angle of the spur.
This is the caliper I chose. It has 2 live pistons of good size, it is aluminum so it is light but it was not thick enough so I made aluminum blocks to increase the width. It fits easily around a 12 inch rotor and 100% of the 2 pads ride on the rotor.
This is the assembled unit. The handle works smoothly, the travel of the master and the handle seem about the same. The master bottoms about the same time as the handle runs out of travel. The master has a powerful spring that pushes the handle back smoothly when released. It really feels good.
All I have left it to remove the trailing arms. They were coming out anyway for routine inspection and bearing checking and I will make a nice caliper mount and weld it to the arm. I intend to mount the caliper out front at about 2 oclock on the passengers side and 10 on the drivers side but that could change when I go to mount it.
All I need is some brake line, 2 flex hose and I should be in business.
Marck I am not sure if you can use a hydraulic setup. My son ships argos overseas and they need mechanical emergency brakes.
