8
		86er
Hey all!
86er here, fairly new to this forum, but have gained much already and am a novice in training. I recently purchased a 1986 L98 Coupe with aluminum heads several months ago. The car was so stock I think everything was original.... plugs, cap, everything!!!! Car ran ok, but ran very sleepy.
With the forums help I've done the following mods with ease and most of them free or almost free and have noticeable performance gains and responsiveness, the car is now ALIVE and runs awesome! Not too many hours invested in time either.
$0 Removed & Cleaned IAC and housing
$0 Adjust IAC idle @ 500
$0 Adjust TPS @ .646Vdc
$0 Adjust TPS at Wide Open Throttle @ 4.53
$0 Cut Air Lid
$0 Removed & Cleaned Throttle Body
$0 Descreened Mass Air Flow Sensor
$0 Adjust Timing to Factory Setting (for now)
$0 Flowmaster Mufflers (FREE from buddy)
$0 Clean in between radiaotr (8" of debris)
$50 K&N Air Filter
$85 Hypertech Power Coil Ignition System
$16 AC Delco RapidFire #5's (gapped @ .045)
$60 MSD 8.5mm SuperConductor Wires
$35 Brake Pads - Front
$11 160 T-Stat (Live in Florida)
$30 Hypertech ThermoMaster Chip (mainly for fans)
$4 Replace PCV Valvle
$45 Balance Tires
I am more than happy with resluts, found lost double digits of horse power, worth every penny and every hour. Car averages 165 degrees on highway and 195 in traffic in 90+ degree weather.
Now that shes running perfect, it's time to start spending some money for some feel it in your britches mods. Mods above have greatly improved performance, but only improved moderately over stock peak performance. You cant expect a couple hundred dollars and a Craftsman tool set to yield too many ponies more than what she came with originally. But I'm squeezing them out little by little. :L
In my quest for more HP, I am looking to do headers next, and expect to gain about 25hp with current mods, but also want them in part to clean up the sides of the engine. I already have true dual exhaust in garage waiting for headers, which I'll proablly run with hi-flo cats straight to the back. I am also looking to do larger runners and plenum porting to match. This with headers and hi-flo's should help it breathe a little better.
Any other moderate performance suggestions without going into engine too much????????
$0 Cut Air Lid
$50 K&N Air Filter
$45 Balance Tires
	 Make her look nice and take her to the track
  looks like you've done your homework :cool   What's the ultimate goal?
