need 78 cruise control parts
srs244
the deep south
1978 pace car, 04 CE convert
i need the following cruise control parts for a 78 L-48, automatic with T&T that somewhere along the line had the cruise unit partially removed and fully de-activated:
1. the servo rod (the rod from the servo to the throttle assembly) the rod with the "hook" on the carb end
2. the pin that mounts on the throttle assembly for the servo rod connection
3. the cruise control transducer (proper 2 wire unit fits 78 and 79), in working condition
4. proper turn signal stalk with cruise activation button (i know it is being reproduced, but i would prefer an excellent original to a repro if possible)
many thanks if you can help me out.
steve
Just saw your post and I recently replaced my transducer and upper speedo cable on my '78 SA L48. Got everything from Rik's Corvette Parts. He had the original 2 wire transducer that was proper for the '78, (even had the correct stamp code). So if you are having no luck finding from individuals I would highly recommend them. Just check the web under rikscorvetteparts.com, (may not be exact but google search will turn it up.
thanks for the info. i have found the correct transducer at a couple of the usual places, but a few of the basic parts (like the rod from the servo to the accelerator link clip) are tough to find except via salvage. i was hoping that perhaps someone had collected some of the stuff along the way and no longer had a need for it. (BTW it hasn't happened yet, lol). i did get a rod from one of the salvage places at a halfway decent price, but i don't have an original transducer (for a core replacement). sthe stuff shows up efvery once in a while on ebay, but like you, i would be more inclined to buy a rebuilt one rather than a proper "used" one.
thanks again.
steve
