BlueCorvette
This is my first engine top end rebuild, so I'm trying to be careful and think everything through. Here is a barrage of questions.
The Crane tech recommended Crane Gold Race Extruded Rocker Arms 1.6 11759-16, I have rod guides in the heads, plus Crane Valve Spring and Retainer Kits 11308-1 to match.
I am replacing all the gaskets. Is there anything wrong with these Fel-Pro gasket kits?
Fel-Pro HS7733PT6 - Fel-Pro Head Set Gaskets
Fel-Pro CS77332 - Fel-Pro Conversion Set Gaskets
It looks like black RTV was used for sealant. I have ultra black, but I am using synthetic oil. Should I use Permatex 81878 - Permatex Ultra Copper RTV Silicone for synthetic oil resistance?
Is this any good for an assembly lube?
Lucas Oil 10153-1 - Lucas Semi-Synthetic Assembly Lube
Is there any difference between the Sealed power and Fel-Pro head bolt kits?
Sealed Power 260-2500 - Sealed Power Replacement Cylinder Head Bolt Kits
Fel-Pro ES72856 - Fel-Pro Head Bolt Kits
Do I need additional thread sealant for the head bolts?
What about the Sealed Power timing chain kit? This is $15 Do I need to spend more?
Sealed Power KT-3499S - Sealed Power Timing Chain Sets
Can I buy a sub $100 aluminum hi flow water pump, or do I need to spend hundreds on one with a CNC impeller?
Thanks, I'm trying to work through everything I need to do the reuild
