alyevich
In need of some advice, as usual (hopefully someday I can reciprocate with advice for others).
My blower fan is making some noise. It's most annoying in low speed when the ignition is first turned on. It's not a bad bearing, but rather it seems that fan impeller is rubbing through a portion of the rotation.
Looking at the location of the motor, it seems nearly impossible to access.
Is there away to access the impeller/fan itself through the glove compartment area? I am thinking I might be able to just make an adjustment to the impeller or perhaps there is a leaf, piece of duct tape, or something stuck in there.
Thanks,
Al
Thanks,
Al
