I need a favor for someone to run me a DTD for my 406 that I will begin to build in February.
1. 406 CI, 4.155 with 3.75 stroke
2. Canfield 200 CC Part # 23-500-65 2.05/1.6 w/.560 lift springs 72 CC Combustion chambers
VALV LIFT .100 .200 .300 .400 .500 .600 .700
Intake Port 72.0 145.0 201.0 247.0 258.0 259.0 259.0
Exhaust Port 53.0 107.0 143.0 175.0 190.0 200.0 203.0
3. TPIS MINIRAM intake with 58 MM TB
4. 1 ¾ Hooker 2149 coated headers into 2.5 inch exhaust with no cat and Dynomax super turbo mufflers
5. TPIS ZZ409 hydraulic roller cam single pattern, .525 lift and 225 degrees duration at .050. Also Com Cams retro rollers and Pro Form roller rockers 1.5 ratio or 1.6 if this is better
6. Street use an occasional track use
7. 1985 corvette with at 3500 lbs
8. T-10 4+3 manual transmission
9. 3:07 rear gears
10. 5.7 5140 Eagle I-Beam Rods
11. KB Signature Series Hyper / Flat Top piston
9. 3:07 rear gears
