D
devilfish
Hello
COuld you give me som feedback on this please?
Im on a tight budget,so keep that in mind. And Im from Sweden so many thins is hard to get "over here".
And its for my 1991 6spd vette.
here is the list:
LPE219 cam
LT4 springs, reatiners etc. ( im not going abow 6000rpm, so it should be enough)
accel superram bas ( ony base )
as+m runners.
ported stock plenum, to match the as+m runners.
Stock TB.
Going to cheap port the 113 heads myself, match it to the accel base.
manley vavles ( stock size )
Increase the comp using a diffrent head gasaget then stock.
heddman headers.
1,5rr, i dont think the stock heads can flow abow .500 in lift, so i stick to 1,5.
no egr
no airpump.
And to add in the future..
superram plenum and runners
hooker headers
AFR heads
1,6 rr
stronger springs
bigger vavles
Does this sound like a good "cheap" top end for now?
Is 370hp possibel with good tuning?
devil....
here is the list:
LPE219 cam
as+m runners.
Stock TB.
heddman headers.
no egr
no airpump.
hooker headers
AFR heads
1,6 rr
stronger springs
bigger vavles
devil....
