zagger
I've just replaced a cracked radiator but the coolent temp still rises above 227 and the fans will not go on. If at that point I turn on the A/C I can hear the fan kick in and the temp will quickly come down to 194/196. There are no more leaks in the system ( new radiator ), I've tried switching the relays under the hood to see if one is bad but it made no difference ( switched coolinf fan 1 and 2 since they are both identical ). The car runs fine with the A/C on but I'm afraid of how high the temp will go without it, It should run same temp with it on or of? I also checked for codes and have none! Any Ideas, I need help.
Thanks in advance
Thanks in advance
