hi guys
i was replacing the aftermarket POS crappy radio a previous owner put in and the antenna cable fell apart in my hands at the end where it plugs into the radio.
How difficult is it to replace this cable.
I see where it runs thru the center console, behind the rear seat, up along the drivers side rear wheel well and than goes behind the rear speaker into the bulkhead area.
How difficult is it to pull and feed thru a new cable behind that bulkhead in the rear?
I looked under the car and see where it somes out and than plugs into the power antenna but i'm not sure how difficult this is going to be to pull the old cable out and feed a new one in.
also where the cable exits the car to the outside underneath shouln't there be a rubber gromment there? my car has no gromment that I can see. From under the car all I can see is a big hole that the cable comes thru from the inside bit no gromment in that hole.
thanks for any help.
