TriTown
Can anyone help me locate a guy that REALLY KNOWS how to work on tune port injection? I'm located in the Milford, Massachusetts area...I've been told more times that I want to hear, "The car is too old to fix".
My problem is that my 85 coupe has a wicked stumble off a stop light. So bad it will stall if you don't nurse the fuel and clutch to get going (replaced the throttle switch, set at .54) The car has all the get-up and go I think an 85 should have and runs great if you keep the pedal on the floor. As for the driveability in traffic it's just the worst! Say in 3rd or 4th gear with rpms steady and appropriate for that gear in traffic the car is not smooth it is serging and bucking. If I'm reading the service manual correctly the book referes to this as Chuggling.
What I've done so far besides spend money on repairs at shops that have had no luck or cure is replace the IAC valve, O2 sensor, set the timing, cleaned the throttle body. Who knows what the shops really did.
I'd really apreciate any feed back on who to go see with this problem.
Thanks,
Joe
PS... I was told by one shop that the PROM is the original. GM was supposed to have had an up grade or two somewhere along the line. Can't find any info and Superchips has never returned my email or call.
Thanks,
Joe
