Hib Halverson
I'm working on "Yellow Thunder" my old 71 hot rod and the ex-Vette Magazine "BBfH" project car. I had it up for sale but after three months and no serious offers, in spite of a price reduction, I've decided to take it off the market for a while and do some more work to it.
One project is to replace the Edelbrock air/fuel ratio meter and narrow-band oxygen sensor I've had in the car for 15 years or so with a more modern and more accurate Auto-Meter AFR gauge which uses a wide-band O2S. This process forced me to deal with a long-standing high ground resistance problem the car has. Many of the aftermarket electrical accessories in the interior are grounded to the "birdcage" at a grounding point behind the passenger side dashboard trim. The problem is between that point and the negative post on the battery I read 8-8.5 ohms resistance, which is too high.
The service manual only notes the existence of "instrument panel cluster" and "console "cluster grounds" not the locations of those. My guess is both of them are located behind the dashboard trim somewhere on the metal of the birdcage structure. Does anyone know the locations of those grounds to a higher level of accuracy than I find in the FSM?
Also, is the birdcage grounded to the chassis through its mounting bolts or are there grounding wires or straps and if there are wires/straps, does anyone know where I'd find them?
Lastly, if anyone here has experienced the same problem, ie: high resistance in the ground circuit between body grounding points and the negative battery post, please post your experiences.
