Need help car went crazy
Pac-man
Barrington, R.I.
1999 triple black vert.
Any advice please. I was driving home and every lite in the dash went on! DIC stated driving under reduced power, shocks unresponsive, gas gauge went to zero, temp went to 260. you name it, it did it, but somehow I went another 2 miles home. Shut car off, restarted and all is good. except pass window will not go down, and it went down five minutes previous to the problem. As an aside, this is a vert, and on the pass side there seems to be a ground wire that has come loose and is hanging behind the pass seat from the top. Noticed this last week. Thank you all.
Hi there,
Check your passenger door connection between the hinges at the A pillar.
You most likely have a spread terminal connection at the 6 pin female connector.
Thats what kills your communications line and can render the door inoperative.
Allthebest, c4c5
Thank you and I will check it today. Would that have made all of those lights and messages go on like that?
Miraculously the car is now fine. If it happens again I will do as you said C4C5< thank you
