Zixxer
I'm replacing my antenna which prompted me to remove the rear wheel and housing. Which by the way is the best thing to do because squeezing my hands up into that area was just cutting my hands all over the place....and the frigging rubber @$)*@)#*@ Anyways, that's going smoothly now but I've notice two wires that end without a connection. Both are clearly grounds as they originate from the ground screw post on the antenna. If you recognize either of these, especially the one on the upper wheel well, please chime in. Everything on the car works but I would sure like to figure this out before reassembly. Thanks in advance.
First picture will be of the left rear wheel well. The protector ground wire ends at a plastic holder and was just taped off. The second picture is a ground wire off the antenna with a plastic clip that makes it seem it needs to be anchored before it connects to the device it should go to.
