Need help to identify which 4 speed
  • Thread starter Thread starter GERALD
G
GERALD
I have a 79 L82 4 speed how to identify which 4 speed transmission I have these numbers on the passenger side of transmission 1304065903 W.G. DIV. I thank these numbers are right from what I could see whith out puting up on ramps
I have since got info. from a other forum by runing the the numbers on the transmission it is a Borg Warner Super T10 THANKS FOR YOUR HELP
Warner 4-speed
Gerald,
In '79 there were 2 Warner 4-speeds available. A close ratio (code UK, 2.43:1 1st gear) and a wide ratio(code UH, 2.64:1 1st gear). Code will be stamped on the left side at the top rear of the case.
Tom
