elkabong
I have a 84. I just installed a ported manifold and 1.6 rockers. After the install of the parts. I was ready to fire her up, hooked up the battery and gave the key a turn, there was a slight crank and then she went dead. I checked the fuses in the fuse panel and all are good. I checked voltages passed the fusable links by the brake booster and all is fine - 12v. I have voltage going to the alternator and to the distributor. The lights in the hood are off and the dash does not light up. The car is basically dead. If I had pinched a wire or something I would have expected the car to show some sign but not total darkness. I understand the basics for electrical stuff. Can someone point me in the right direction?
Thanks in advance.
