Need Help with 90 Coupe
  • Thread starter Thread starter my90c4
M
my90c4
This problem started after I had the intake manifold resealed as I had a serious fluid leak. Idles rough and stumbles while running, ECM shows a code 42. Suggested that ignition module or ECM be replaced. Could this be a vacuum problem or spark plug wires ? At a lost need help, please! Only have owned Coupe for a year and only has 25,000 miles on it.
Thanks in advance for all your help.
my90c4
I know after my bro had his engine rebuilt it ran like crap as you are describing. They tracked down the vacum leak. I would say that it probably is the culprit in your case. I also hope that is the problem. Good luck and let us know what you find.
Craig
Your on the right track
Mine had a similar happening about a year after I got it. I'm not sure if it was the Ignintion Module or the ECM. I replaced both plus the distributor wiring terminal as it broke where the hold down screw was. The '90 uses the seven pin Module and I think I got the ECM from Autozone. Haven't had a problem since.
:w
:pat
