V
Vette 76
Hi, I am rebuilding a 72 454 roadster and was needing help in finding sources for fender flares. I want to use a minimum of a 10" rear rim, possibly even as much as a 12". How much room will offset trailing arms allow me next to the inner fender well? I have room to cut or do just about anything needed to modify for wider tires at this point because I have just completed a conversion from the original 72 coupe to make it into a convertible. I had 68 and 75 convertible rear clips that I used for the correct parts. Ecklers has been the only place I have found flares but they only have one size. How much flare do I need? I also want to put in a plug for this forum. You folks are great! This is my second vette to rebuild and you folks have been wonderful each time I have had a technical question. It is an honor to be a part of this corvette community. Thanks, Vette 76
. I am at that point in my 72 rebuild and would like to order a set of flares. Could you tell me how to find ACI products or how I could get in touch with someone who could get me that info. Thanks, Vette 76
