Need help !
somerset, ky
I am at my wits end on this one. My 93 started running screwy awhile back. Checked the codes and found # 2 injector was fading out. Replaced the injectors and while I was at it also replaced the fuel pump and screen and fuel filter. Now the car is running like crap again. Throws no codes. Its like it is running out of gas, peddle it a little and it picks right up and goes fine. Any suggestions? Thanks Mike. Also the opti only has around 20K on it. Just doesnt feel like a fire problem but more like a fuel problem.
You don't say if the injectors, fuel pump and filter fixed the issue? Did it run better then deteriorate or was all the work a total miss?
If you have no codes to guide you I would go with your gut concerning the fuel issue but instead of putting parts on try testing the pressure first, could be a bad regulator.
If the pressure is good and the fuel is not old or otherwise contaminated see section B in book #2 of the FSM for "Symptoms" diagnosis when there are no DTC's starting on page 6E3-B-1, good luck.:thumb
