NORMAS VETTE said:
I Own A 1998 C5 Spiral Grey. Really Nice Car. As Of A Few Days Ago I Got Check Engine Light On, Traction Control And Reduced Engine Power. Not Many Codes...only C1221, C1278. I Also Got A Code Of P1515 Only Once. The Car Goes Into Reduced Engine Power As Soon As You Accelerate. If Anyone Can Tell Me What Is Going On I Reallt Truly Appreciate. I Just Became A Member And Really Am Desperate. If Anyone Can Help Please Help!!!!!!
Thank You
Normas Vette
HI there,
The P1515 is what the 'Reduced engine power' is being caused by.
This is telling us that the computer wanted to see the throttle plate at a certain location, and it does not get there. So, in order to avoid a problem that could be alot worse, it defaults and shuts down the throttle control system.
So, there are a few things that could be causing this.
First, 1998 was a tough year for TAC, or the throttle actuation control modules. There were a couple of changes to the modules over the first 3 years of production.
Second, take a look at the picture. This location is where the wiring will rub through, causing all sorts of TAC codes and problems. I would suggest pulling the wiring back if it is contacting the fuel rail safety bracket.
Third, mods have been known to cause this code sometimes. Does the car have any aftermarket accessories????
The 2 TCS codes, C1221 which says that there is a problem with the left front wheel speed sensor, and C1278 which says that the TCS/ABS has been disabled will not cause the reduced engine power. It will shut down the ABS, but that is about it.
Please clear the codes after you move the wiring harness, and let us know if it comes back.
Allthebest, and welcome to the CACC.
c4c5
