here ya go....
Exhaust Systems
Catalytic Converters - Super High Flow
There's no need to sacrifice gobs of horsepower to meet emissions requirements. All you need is a properly tuned and maintained engine and Super High Flow catalytic converters featuring 3" diameter inlets and outlets. TPIS SHF converters meet EPA and California ARB requirements. They can be added to vehicles that were not originally equipped with a catalytic converter, or installed as replacements when required on late model emissions controlled cars and pickup trucks. Special flow-enhancing construction minimizes mechanical restriction for maximum horsepower. Dyno testing has shown less than a 3 HP loss when TPIS SHF catalytic converters were installed on an open exhaust system. Custom-size inlets and outlets are available on request.
Note: Under Federal EPA regulations, replacement of original equipment catalytic converters is allowed only if the original converter(s) is missing, or the vehicle has more than 50,000 miles or is at least five years old and the need for a replacement has been established and documented or a local inspection program has determined the existing converter is in need of replacement.
200-400 Catalytic Converter, Universal 3in slip fit in/out........$210.00
200-401 Catalytic Converter, 1984-85 Corvette, 4-bolt flange - Also fits our LT1 Race System........$220.00
200-402 Catalytic Converter, Corvette/Camaro, L98, 1986-1991, 3in Slip-in, 2-bolt flange........$220.00
200-403 Catalytic Converter, Camaro, LT1, 1993-1995, 3in Slip-in, 2-bolt flange........$220.00
200-404 Catalytic Converter, Camaro, LT1, 1993-1995, w/TPiS or JBS Headers, 3-bolt flange........$230.00
200-405 Catalytic Converter, Camaro, LT1, 1993-1995, w/Edelbrock or SLP slip-inlet headers........$220.00
200-406 Catalytic Converter, Chevrolet PU/SUV/Suburban, 1987-1993, 350ci, slip-on both ends........$205.00
200-407 Catalytic Converter, Chevrolet PU/SUV/Suburban, 1994-1995, 350ci, slip-on front, flange rear (305/454 also available)........$218.53
