Welcome to the Corvette Action Centre! I'm sure you'll enjoy the Forums!!dsbjc4 said:i would like to add a little more power to my 1974 454 with out getting to radical. i was thinking maybe a cam and porting the heads. any suggestions?
If it is the stock 454 from 1974 (last year for a big block if memory serves) then it's an LS4 only rated at 270 hp. The L82 at 250 hp with lighter weight was a better bang for the buck and had better performance stats. Last year before cat converters became mandatory as well.JBsC5 said:More power than a 454 ...
Wow! I never thought I'd hear that!
Awesome!
c5d said:I suspect the '74 is a 3999289 casting, 2 bolt main.
A 2 bolt block with splayed caps (angles the bolts outward 18 degrees to utilize the inherent rigidity in the cylinder walls resulting in an arrangement that is stronger than the straight bolt cap arrangement) will certainly handle up to 400hp, with a max at 500hp. If the caps are straight, then 400 is a good limit.
The 2/4 bolt determination is important for a couple reasons. Not knowing which HP figure dsbjc4 is looking for (although I did dismiss the LS7/465hp as too radical), if he chooses the 450hp, the 4 bolt mains are probably necessary.
And since LS6 (& LS7) HD engines used a 7/16" rod bolt, and presumably other HD components, these parts, if selected, may require 4 bolt main clearances.
If selecting the 390/365 versions, there probably is no need for concern with a two bolt main.
C'ya & Merry Christmas
D
dsbjc4 said:I am thinking about a comp cam set up I have had good luck with them before. do you think i should leave the heads alone or do a little pocket porting? what size cam would work good? edelbrock,holley, or stay with the Q-jet? i don't know much about a B/B.
dsbjc4
jfb4548 said:Anything more then a good valve job and valve seals and maybe replacemnt valve guides if needed is a waste on a street motor.
Spend your money on a good intake and carb, cam, lifters and valvesprings. Call any of the cam company and they will give you the correct parts for your applaciation...They are the experts, no need to reinvent the wheel!
