New 74
bobmo
Lancaster, VA
1987 Bright red, 1974 coupe--Basket case
Greetings,
I have just bought a 74 coupe, Automatic, with '72 400cid. Its a fixer-upper.
But at least I have a mission for Carlisle this year.
I am looking for the VIN plate and have not found it yet. Does anyone have any clues? or is it to early for VIN's.
Also, I will be doing a full restoration, and could use some help in learning about the 'hidden' problems that I might overlook.
Bobmo
T
tom102
Vin #
It should be on the drivers side windshield pillar visible through the windshield about two inches or so up from the bottom.
bobmo
Lancaster, VA
Thanks, I was looking down on the door post.
CQRT
Scottsdale, AZ
2003 50th Anniversary coupe
should be something like 1z37j4s4xxxxx if it was originally a small block L-48 coupe
R
Robin7TFour
hello, Bobmo welcome to the CAC. great bunch of folks here! and i see you've gone to the dark side, ahhh the 74's we are a special breed. the fixer-uppers!!
robin
bobmo
Lancaster, VA
Thanks Robin,
The fixer upper is my middle name.
I have an 80 xj6 jag, 1987 xjsc jag ( v12) that fit the fixer class, and then there is the 86 cougar and the 92 Mazda PU, and the boats, and the kit car and the house.
I live for the fixer uppper!
I have the life time supply of rainy day projects.
Bob
