new brakes
jjarrett
north carolina
1990 black coupe
hi! I JUST BOUGHT A 76 COUPE THAT HAS BEEN STORED FOR 4 YEARS OR MORE,AND JUST ABOUT EVERYTHING I TOUCH EITHER BREAKS OR FALLS APART.THE DASH IS OUT,ALL OF THE HEAT AND AIR DUCTS ARE MISSING,ETC. MY QUESTION IS THIS-I'VE REBUILT BOTH FRONT WHEELS,AND CANNOT GET THE CALIPERS TO BLEED BY PUMPING THE BRAKE PEDAL.ANY COMMENTS? THANKS----JOHN
6880 Mike
The Bluegrass State
1968 convertible; 1980 L-82
...I'VE REBUILT BOTH FRONT WHEELS,AND CANNOT GET THE CALIPERS TO BLEED BY PUMPING THE BRAKE PEDAL.ANY COMMENTS? THANKS----JOHN
First thing to do is turn off your caps lock key. Second thing is to tell us how you've been trying to bleed the brakes. Unless you use a power bleeder, bleeding brakes takes two people.
jrzvette
NJ
1969 RED SB COUPE, 1993 BLACK ZF6 COUPE
hi! I JUST BOUGHT A 76 COUPE THAT HAS BEEN STORED FOR 4 YEARS OR MORE,AND JUST ABOUT EVERYTHING I TOUCH EITHER BREAKS OR FALLS APART.THE DASH IS OUT,ALL OF THE HEAT AND AIR DUCTS ARE MISSING,ETC. JOHN
Sounds like that car was in very poor condition when it was put into storage. Unless it was "stored" in a rain forest it shouldn't be in that bad of a condition after 4 years.
jims427400
Temperance Michigan
67 427 tripower,68 427 tripower,04 Z16, 62 340hp
When I replaced my entire brake system on the 68, I used 4 check valve bleeders (1 on each caliper) about $15/pr. from any corvette vendor and they worked great by myself. Well actually I had the wife pump the breaks, she did'nt complain too much.
fine69
Maryland / D.C.
'69 Convertible Vette; '72 Z28 Camaro Rally Sport
jims427400
Temperance Michigan
Thanks fine69,
Could'nt remember what they were called..
I'd also recommend upgrading the brake fluid, does'nt peel the paint and resists moisture.
jjarrett
north carolina
1990 black coupe
thank you for the response to my query about brake bleeding! i will follow the advice given and will buy the speed bleeders. thanks!!! john
