I talked with the techs last night, and I finally understand why the parts are taking so long (warranty issue). They said that they have never seen this happen before, and my vette is up on a lift in a million pieces (more info than I wanted to know). They are replacing the transmission main shaft, and possibly the whole transmission all together.
This is what they did to it to get 500HP - Package includes West Coast Corvettes' modified cylinder heads and cam package, hardened pushrods, cold air screens, Twin Flow Air Intake, throttle body by pass tube, 172° thermostat, head bolts, adjustable fuel pressure regulator, recalibrated engine control module, Max Flow Mass Air Sensor, 1030 cfm throttle body, Twin Flow exhaust system with X pipe, T-body By Pass Tube, Nology Wires, Beru Plugs, B&B Headers, Gasket Kit. Top End Performance Package, Billet Stroker Crankshaft(Keyed), Billet I Beam Connecting Rods, Forged J&E Pistons, Speed Pro Piston Rings, New Timing Chain, Clevite 77 Bearings, Balanced Rotating Assembly, Custom Performance Machine Work, Hand Assembly & Custom Stage V Computer Program. This is a turn key Package & will pass California emission tests. Dyno tested @ 480 HP/475 ft lbs torque plus aftermarket exhaust system of choice.
Thanks for the 2 cents Pete, I NOW completely understand that logic!
