midyearroadster427
- Joined
- Jul 25, 2004
- Messages
- 191
- Location
- Massachusetts
- Corvette
- 1967 Red 427 Roadster, 2012 Grand Sport Coupe
starting to install new front carpets from Al K. I have the cabin insulated and the carpets are sitting in there resting...now, the question...it appears there is some extra material and it will need some triming but also when I test fit and press the carpet up against the tunnel areas a wave forms...you can press most of it out but it tends to move towards the front....when you install carpets do you have to make a deep cut at the front corner to get this wave out..or..should i use alot of heat to see if this wave of material conforms down to the tunnel area...a smaller wave is on the outter side too....just exactly how much cutting and triming did you have to do to make the carpet lay down nicely???? first time doing this type of thing....sorry for the newbie questions...
