How do you remove the pin on the factory gas pedal? I want to change it to a aluminum one, and I can't even see how the original pin is on there. I bet it will be pretty simple. ThanksScott
I just did it recently. I pushed on it from the side closest to the console. On the side closest to the brake, the pin has a head on it. After getting it out a little i used pliers to pull it out. The real fu part is getting it back in. The problem is that when it goes bak in the spring thing that is behind it gets in the way of the pin going through the holes. I tried for a while and finally bent the spring some so that it could pass through. After i bent it the pin went through with no problem. Good luck.
