well, I was painting an air cleaner housing yesterday.
It was is decent shape so I didn't glass bead it first to strip all the old paint off but I cleaned it well, used a 3M scotchbrite pad to rough up the surface of the existing paint, and to clean up a couple misc small rust spots than painted it with a pint of Rustoleum gloss black I had with a small foam brush. Overall it looked OK except for some minor brushstroke marks from the brush so I wasn't happy about it. After it dried I lightly went over it again with the 3M Scotchbrite pad to flatten down the brushstroke marks and figured I'd hit it with some Krylon gloss black paint I had in a rattle can.
BIG mistake!
The instant the Krylon rattle can paint hit the surface of the housing it immediately bubbled up all the paint that was there like I had hit it with lacquer thinner or paint stripper!
Now I get to sand off all the paint completely now and start from scratch.
I know the Rustoleum paint is an enamel but the Krylon can didn't say what it was (not that I could find on the label anyway) but they way the two paints didn't play well together I'll have to assume it was probably a lacquer paint.
so, lesson learned here......... paint is like alcohol. DON'T mix two types if you are indulging in either activity. :eek
If you don't know for SURE what both types of paints are, play it safe and don't mix them.
By trying to shortcut myself on this part i've ended up doing nothing but create more work for myself in the long run.
Note to 67Heaven: Bob, I know this pertained to a part from my other car, but I posted it in here and i'm hoping you will let it stay because it's an issue that isn't specific for any particular generation but rather a lesson learned about painting parts that may benefit other people like myself that are new to doing things on their own and could just as easily happen while someone works on their C1/C2 cars.
BIG mistake!
