WAKE UP!!!!the intake , carb, and distributor change was to make it BETTER!!
stock ignition is good for 4500 rpm, hei goes to 6000. the intake if a performer is near stock, if it's a performer rpm , you have a great dual plane intake that many people are switching to cause it adds lots of low end grunt. the holley carb, 600. is perfect for that motor. the quadrabog , with those huge secondaries will bog when you tramp it down,the holley, if set up right, will cause no delay.
sounds to me like your on the path to 300 h.p. , a far trip from 205, and you want to go back.??
here's what's next, a good high lift cam, about 460 lift,240 duration, some headers, full duals with turbo mufflers (quite open), top it off with the torque convertor reccomended by the cam people, 2000rpm? and add a nice shift kit and some 3.73 rear end gears.
finish off your setup and enjoy some real h.p. unbuild it and regret it.
notice how everyone (include me)want your old parts???do the math. save the old parts for if you want to sell it as original, but h.p. is something that lacked in those cars(mines a 75 even worse 165hp.).If you find a problem with power as it is , maybe the carb was never set up properly, the power valve must be changed with the cam to keep peak power, also, you should have the distributor recurved, if you have no power, it's set up wrong, that thing should move well as is.mike
