Thanks everyone...here's a rear view and another straight on side view.
I had to take them to 2 tire places, as the first one couldn't get the tire on the rim. The second place also had a hard time, but managed to do it. As far as the balancing, the guy was surprised how close they were...like maybe 1.25 off. He used the stick on weights on the inside of the rim, so you don't see them, and they balanced perfectly!
The tires are amazing...Dunlop S9000, rated 10 in dry and 10 in wet traction. These things grip! Got them from Tirerack.com as they had the best price...even better than a huge discount at Goodyear from knowing the district manager!
Oh yeah, the backspacing is 4" on all 4...I used offset trailing arms, although I didn't need to. Originally I was going to go wider in the rear, but they couldn't make the rims with the same type of lip as the fronts would be. So, I opted to stay witht the 10".
Also, my car has the Duntov Turbo body kit on it, so that's why my fenders are so wide, and why 10" rims w/4" backspacing fit's perfectly.
I put lowering bolts for the rear spring which helped bring the car down, but the front is sitll way high! The springs are relatively new, the previous owner had them installed in 2000, so I figure they must be settled by now. What kind of clearance do you guys have between the tire and the wheel well? From others I've seen it seems like no more than 2 in.
If anyone has any questions, please ask. I just finished doing the following...New Offset Trailing arm assemblies from Van Steel with new SS parking brake hardware and rotor, Half Shaft Rebuild w/new U Joints, Poly strut rod bushings, New front rotors and calipers, full pressure bleed/flush.
Finally after a long time, I can drive with confidence. I don't know if any of you know but, a while back I had posted stuff about my wheel almost falling off. It broke off 3 studs and was hanging on by 1 lug nut. That started a snowball effect of problems, that prompted me to want to get rid of those other wheels, which were using spacers and longer studs with unilug wheels. Anyway, that incident messed up my runout and caused my brakes to be bad.
Well, after a lot of time and $$$, things are great again, even better than before, and I'm thrilled. So, thanks for looking and tkaing the time to read (sorry so long).
- Jeremy
