If you are breaking loose at 20-30mph, you are probably running crappy run-flat tires that are mostly worn out. Let me know if my guess is correct. Another possible cause is many of the performance tires available, especially Bridgestone Potenza, are terrible in the cold weather. With the proper tires, there is no way you can break that car loose at 20-30mph. You have an obvious traction problem. I'm running non-runflat Goodyears in Z06 sizes and its tough to break it loose. You are probably not gripping in the corners as well as you should be either so be careful. I crashed into a stone wall taking a tight corner on Pirelli Asymetrico's that where half worn in cold weather. And one last time, Run-flats are terrible in cold weather, would never trust them. Like driving on rocks.
