nitrous kit, 250hp wet
  • Thread starter Thread starter chevyandgmparts
C
chevyandgmparts
I am selling a nitrous kit. It is set up to go on a ls1 but can go on almost any motor. It has two duel inlet soft plume nozels with steal braided lines y-ed into a nitrous sylenoid and fuel sylenoid. The fuel system is a 1.5 gallon jaz tank, uses a holly blue electric fuel pump. Goes through a holly regulator to the sylenoid. By running a seperate fuel tank you don't run the risk of running the motor lean during activation. There is a nos psi gauge on the fuel system and on the bottle. The bottle has a blow down tube on it. The only thing I am missing is the bottle brackets. I did not use them on my aplication and don't know where I placed them.
I have over 2k into it with the fuel system and the extra parts.
I am asking $750 for the complete kit. (not to bad for all the extra horse power and the badest kit money can buy with out going multiport)
any questions
call (916) 276-3593 or email chevyandgmparts@sbcglobal.net
Eric
nitrous kit
Hi,
I have moved the battery to the trunk on my car to comply with track rules. I mounted the fuel tank where the battery was. This is not a novice kit though it takes an experienced installer to have a clean look. You can mount it almost anywhere though. I don't know where you live or your mechanical ability, but If you live near the sacramento area I can instal it for you. If not any good mechanic should be able to set it up with a clean look.
Thanks,
Eric
(916)276-3593
