No courtesy lights 96 C4
captainrags
Ft Lauderdale
1996 red coupe lt4 manual 6 speed
Lights stopped working in the front part of the cab, no doors, no under dash, no light on rv mirror. When entering car that light only works now with key turned on. Any suggestions would help lights in back section work when opening doors fine
:w:w:w
Not being wise here but check the fuse. Mine was out but I didn't get the right one at first and thought it looked good.:confused. I did go through the entire system and found out how everything works and I'm sure I can find my notes on if you need them. Just let me know. PS....don't forget that the courtesy light don't come on in the daylight cause of the light sensor in the dash.
