1989 406
I was having starting issues a few weeks back and thought I had the problem fixed. I put a new starter, battery and heat shield around the starter. I now go out in the morning and drive the car and it is fine until I turn it off. If I go to turn it off and try to start it again, it cranks very slowly and then does not start. If I let the car sit for a while, it starts right up. I am not sure where to go at this point. Obviously something heat related is the issue, that is why I put the heat shield on the starter.
While starting it up tonight after it cooled down, the car was running and I decided to put on the headlights and they are only opening up half now. I am guessing the motor is on the way out. Is there anything else I should check for. At this point I do not even know where the headlight motor is.
Thanks.
Thanks.
