T
Tobben
Hi all, my engine isn't running as well as it should be. Although i used some injection cleaner and cleaned the injectors, after that the engine is working better and better, but not 100%. What i need to do next is to read any fault codes. I haven't any scantolls for the moment, but i have a 16 pin stick on a OBDI system. Where should i jump the wire? Between 5 and? Someone told me between 5 and 6, but if i do that the coolant fan starts and nothing more happens. And how can i delete codes?
I changed the coolant water just a moment ago, after that when i tried to start the vette, it didn't start :ugh I managed to make it start after a while though. I figure the optisparc was the problem. Are those a common problem on late c4? The engine is ok when cold, but with a little heat in the block, the engine is running worse :confused
