WONKABOY
CAN SOMEONE TELL ME THE LOCATION OF THE O2 SENSOR (S) AND WHEN I CHANGE THEM IS THERE ANY ADJUSTMENT , OR THE COMPUTOR DOES IT?
Thanks Rick
Thanks Rick
Sensei said:It screws into the exhaust pipe below the header on the driver's side. No adjustment. God bless, Sensei
Tom Bryant said:The only thing I would suggest is to disconnect your battery for a while to let the memory erase. You can do this while you're changing the sensor. Then it will reset with the new sensor in place. It should speed up the learning curve a little.
Tom
