Oh Boy....1989 miles, "pull key, wait 10 "
Jays Z06
CT
2004 Corvette Z06
Happened to me tonight on the way to my sisters house. I fired up the car, and it stalled. Thought, hmmm, weird! Re-fired it, and it stalled again. S*** was my first word. Then I looked down and saw it"Pull key, wait 10 seconds" I swear to God I thought my heart was going to come through my chest. Luckily I tried starting it about 30 seconds later and all was well.
There was only one recall for the 2004 Z06 for a suspension washer.....no column lock bypass. Should I purchase one and have one put in? or drive around in fear?
Thanks!!
Jay,
I don't know if what you're describing is a column lock issue. Besides, the column lock should be done under warranty- check with your dealer about that.
Are you getting any codes after it stalls?
-Patrick
Hi Jays Z06 -
The column lock problem will show a "Service column lock" message on the DIC.
I think the message you saw precedes the lock issue - you may want to have the CLB done if it has not been done already -
Here is some info on the TSB I found searching.
" Partial Text of Recall 01044A - September 6, 2001
(Note -- this was later superceeded -- see below)
Dealers are to install repair kit PN 88952427 for automatic transmission Corvettes in the US & Canada or repair kit PN 88952428 for all manual transmission Corvettes in the US & Canada.
VEHICLES INVOLVED
Involved are certain 1998-2000 Corvette model vehicles built within these VIN breakpoints:
YEAR - DIVISION - MODEL - PLANT - FROM - THROUGH
1998 - Chevrolet - Corvette - Bowling Green - W5123355 - W5131069
1999 - Chevrolet - Corvette - Bowling Green - X5100001 - X5133283
2000 - Chevrolet - Corvette - Bowling Green - Y5100001 - Y5116233
_______________
Note the VIN number of my car
The most current recall (applicable text only):
GMP04-112 - 04006A - Electronic Column Lock System
MODELS: CERTAIN 1997-2004 CHEVROLET CORVETTE EQUIPPED WITH A MANUAL TRANSMISSION, 1997-2000 CHEVROLET CORVETTE
EQUIPPED WITH AN AUTOMATIC TRANSMISSION, AND CERTAIN 2001-2004 CHEVROLET CORVETTE EQUIPPED WITH AN AUTOMATIC
TRANSMISSION – EUROPEAN EXPORT ONLY.
PRODUCT SAFETY RECALL #04006A - DATED: JULY 26, 2004
NOTE: THIS BULLETIN CANCELS AND REPLACES BULLETIN 04006, ISSUED APRIL 2004... ALL COPIES OF BULLETIN 04006 SHOULD BE DESTROYED.
...2. During quick cranks, the ECL lock pin may not withdraw fully and, in vehicles where there is abnormally low clearance to the lock
plate, there may be contact between the pin and lock plate. This can cause a noise or ratcheting when the steering wheel is turned or,
if there is insufficient clearance, the steering wheel cannot be turned.
If one of these conditions occurs, a crash could occur without warning.
Dealers are to remove the column lock plate on U.S. and Canadian vehicles equipped with an automatic transmission. After the service
correction, the steering column will no longer lock when the key is removed.
On vehicles equipped with a manual transmission, and export vehicles equipped with an automatic transmission, dealers are to 1)reprogram the PCM, and 2) verify there is adequate lock plate clearance and, if necessary, replace the lock plate. After the service correction, the steering column will continue to lock when the key is removed.
GENERAL INFORMATION:
Part Number Description Quantity/Vehicle
88952427 Harness Kit, Strg Whl Theft Dtrnt Lk Shorting (automatics except export vehicles) 1
88952428 Wire Kit, Strg Whl Theft Dtrnt Lk (1998-2000 manuals & export automatics) 1 (If Req'd)
26056108 Nut, Strg Whl 1 (If Req'd)
26094767 Plate, Strg Shf Lk (manuals except exports) 1 (If Req'd)
88964588 Plate, Strg Shf Lk (export) 1 (If Req'd)
05694191 Ring, Strg Shf Lk Plt Ret 1 (If Req'd)"
best regards -
mqqn
Lovely!!! :-)
I'll have the CLB installed at some point.
Thanks for the replies, I'll keep you posted on how things go.
That happened to me about 3 years ago and then it never did it again....until this last June. The column lock mechanism had to be replaced to the tune of $540 plus a tow from AAA (free). My 'Vette had been in for the recall the previous year. You can change out parts at the first sign of a problem and it still won't guarantee that that the new part isn't defective too. Make sure you have good roadside assistance and throw caution to the wind. - Ron
I don't think your problem is related to column lock.But while it's on your mind get a bypass.The peace of mind is worth it.
A weak battery can also cause your same problem...
Jack
Thanks!!
dont wait!!! order a CLB and install it, it takes about 30 minutes.
The condition will get worse before it gets better
I missed this thread earlier. I think that what you are seeing has to do with the vehicle antitheft system. I have had that happen once before, too. The car will fire up, but as soon as you try to move it, the engine is killed. You did the right thing, and I don't think it is likely that it will be a long term issue.
IT IS THE COLUMN LOCK!!!!!!
Do not pass go, do not collect $200.00, proceed directley a CLB saleperson and spend 30 minutes of your time installing it.
Problems solved never to be heard from again.
All of the issues noted in this thread are related to a failing column lock, PUT IN A CLB!!!
