I have a GM oil cooler it sandwiches between the filter and the block and uses engine coolant to cool the oil was on a 87 GTA that I am parting out. you will need to "T" into your heater lines. Make me a reasonable offer before I Ebay it.
Craig sr.
http://www.holley.com/types/Temp-A-Cure_Oil_Coolers.asp
One of these may work for you. They're very light too.
Have you put one of these on. I was wondering what size and where to put it.
I haven't had a chance to put one on. I've been working on a project to help us make them more effectively. They're nice coolers.
You could call the Earl's help line and tell them what you want to accomplish. I think they could give you size guidance. I'll probably grab a set of brake lines before I do a cooler.
I installed the DeWitt today. Sure is a pretty radiator. Drops right in with new pads. Coolant level sensor was a ***** to get in.
Temps seem better. Will know more after road test.
