Oil Leak
  • Thread starter Thread starter CharlesBrown
C
CharlesBrown
Had a motor-oil leak. Dealer fixed it. Cost $142.00. I had oil dripping from the oil filter so I replaced it. Didn't help. The dealer found that the filter did not screw directly to the block, but to an adapter...which was loose. Should you have this sort of leak, save yourself some money as follows. Remove the oil filter and tighten the jam nut on the nipple that the filter screws into. Could save you $142.00
Torque Shop
Dream Giveaway
