A
AUSSIEVETTEMAN
Hi guys,
Just wondering if any of you have had any annoying oil leaks around the valve covers and inlet manifold?
I have a few small leaks that leave oil in the valley of the Edelbrock inlet manifold. I have replaced the valve cover gaskets with Speco rubber jobs twice and still there is a leak. I have a set of cork gaskets I am putting on this week to give that a try.
Valve covers are Edelbrock alloy jobs to cover the 1.6 roller rockers.
Could there be oil making its way up the inlet manifold bolts? Dumb question but I have heard a few guys say this can happen and as a result they put a little sealant on each bolt when installing them.
Could I take each bolt out one at a time and put goo on them or should I just rip the inlet off and try again?
Another guess is that the inlet manifold gasket has leaks - new engine though?
The oil drips down on the rear of the block and onto the starter motor case before hitting the floor. Not much oil, just enough to annoy the $%^& out of me.
I use Mobil 1 as the L81 has new piston caps (has been bored 20 thou) and now has different oiling capabilities. There is a high volume oil pump and pressure is always around 45-50 psi at idle and off the gauge at rpm.
At the base of the HEI dizzy, there is build up of oil, I can't tell if the pressure guage connection is leaking or the gasket on the bottom of the dizzy has issues.
Any tips?
Cheers
Tony
Any tips?
Cheers
Tony
