sunger
I have an oil leak on my 68 427/400, and I expect it is the rear seal. Can it be replaced by dropping the tranny, or do I need to pull the engine to get to it?
Steve
Steve
No,You can just drop the Oil Pan and probly drop the center steering link!!(Probly have to pull the 2 Long bolts in motor mounts to raise the engine a little to clear the pan!!) 68-427 has a 2 piece rear main seal!!! Don't discount the distributer seal,rear intake gasket, and oil line to gage first!!! As they are bad to leak too!!!I have an oil leak on my 68 427/400, and I expect it is the rear seal. Can it be replaced by dropping the tranny, or do I need to pull the engine to get to it?
Steve
Well, the leak has decided not to go away. Only one thing left it could be. Rear Main Seal. So frustrating...
