Oil pressure
norwegianvette
Norway
1993 Aqua Convertible
Hi.
I'm just back inn after a oil and filter change. Pressure used to be 75 % on idle but are now 50 & increasing to 75 % on load. I used a thinner oil this time after cleaning the engine inside with "tuneup". Oil now is Mobil 1, 0-40 insotead of 5-30. Is this normal?
Thanks,
Steve:w
G Winter
NW Iowa
1990 red convert 6 sp
Couple things involved here. I assume you went from conventional oil to the Mobil 1 . The conventional will be thicker when cool than the synthetic.
going from 5- to 0- could make some diff also.
normal ? I really can't say for sure.
Glenn
:w
G Winter
NW Iowa
what oil filter?????
Are you thinking the brand of oil filter may have an effect? You may be right if that is what your thinking. If I remember right a number of yrs ago there was a filter that used cotton instead of paper. They did a very good job of filtering but were somewhat restrictive to the point that people running high RPM wouldn't use them. Puralator comes to mind but not sure.
Glenn
:w
Edmond
Louisiana
2003 Z06
There's an article on this by Amsoil. I'll dig it up and post it here after I watch some Horsepower TV.:upthumbs
norwegianvette
Norway
I always use original parts and so it is with the oil filter. Genuin stuff from the local GM shop.
