Vette79
Is there a good Oil Pump Replacement out there for a 79? Looking for the pickup tube already tacked in place but not necessary. Rear main seal will have to be replaced so trying to prep for future endeavor...
Do I need the Oil Pump, Oil Pump Shaft and the Oil Pick Up? Is there anything else that I need. I will be replacing the rear main seal and the oil pump. I just replaced the oil pan gasket with the one piece fel-pro. Can I re-use the gasket?
