OK, I am stupid-anti theft
P
puppyfang
Well at one time I thought I knew a lot but not so sure now with old age coming...just bought this 1989 coupe....some how I must have armed the anti theft because it will not start...I believe that the way to disarm is to lock the car from the outside, wait a few minutes and then unlock it using the key and then it should start when I put the key in the iginition....right....well tried this and still nothing any ideas or am I doing some thing wrong...confused and frustrated...thanks for any help
G Winter
NW Iowa
1990 red convert 6 sp
Your key has a resistor in it which needs to make contact inside the cyl. You could try spraying some contact cleaner in the key slot and clean off the contacts on the key.
Did you get two keys? Try the other key. One of them may not be correct or nonfunctional.
Glenn
:w
ZumZum
Central Illinois
1988 Dark Red Coupe
Glenn
:w
Good points from Winter. If my VATS (Vehicle Anti-Theft System) gets set off, I usually turn the key back to the off position, then just sit and wait for 4 minutes, turn the key again and it usually fires right up.
If you have alot of problems with it you can buy a VATS bypass system from Mid-America or Ecklers or the like.
P
puppyfang
Finally got it to work...not sure how but I got it started..am goining to bypass the "stupid system"...thanks for input
G Winter
NW Iowa
You actually don't need a kit, just some wire a single throw double pole switch and a resistor equal in value to the one in your key. If you do a search there is a thread on how to do it. I think I may even have it in a word file on my computer.
Glenn
:w
