- Moderator
- #1
vetteboy86
So I talked my wife out of a big SUV and we ended up finding a used Honda Accord. Nice car. So with that said, I am going to keep her 95 olds Cutlass Supreme and drive it to and from work, over driving my truck. As you would expect, the fuel mileages is way better.
Well anyways, I noticed if running a little warm on the gauge, or at least it looked warm. I know the analog gauge's sometimes are not linear. So with that being said, I started to look at the cooling system. To see if there were any issues.
I first believed that the cooling fans were inoperable, because the gauge would read to the second tick mark, and they wouldn't turn on. I tested the fans, and they were good, I tested the relays, and the relay signals and everything checked out. So I just let the car idle in the driveway, and after 20 or so minutes of idle time the first cooling fan did turn on.
So I then looked at the temperature switch. In this case, I thought it would be the same sender as the gauge, but it isn't. I pulled the cap, and the SES light came on. Plug back in SES light went off.
So my questions are: Is there any accurate way to determine how hot the car is actually getting before the fan turns on? Is there any way to test the temp switch? I thought about grounding it to see if the fans would turn on, but wasn't sure.
So now I think it is either a bad switch, or air is trapped in the cooling system, and the gauge is reading hotter than the car actually is.
Sorry it's so long, but this is my new driver, and I know summer is coming!
Thanks,
Craig
Thanks,
Craig
